Meshing industrial scale mixing tank
Old   April 26, 2011, 15:18
Default Meshing industrial scale mixing tank
David Russ
mlbontbs87 is on a distinguished road
I am trying to model an industrial scale mixing tank (500k-1M gal). The tank is baffled with a pitched blade impeller. I am using MRF and 5 Eulerian phases to simulate solids behavior. The solution is steady state.
I have modeled this correctly for a 1/2 gal lab vessel, and am now seeking to do scale up. My original mesh contained 509k cells. When I try scaling in Fluent, the system diverges immediately. Now I am trying to refine the mesh in Icem to model the larger tank.
My question is this: is there any rule of thumb for how high the mesh count should be? No one in my group has modeled anything this large before.
Thanks
mlbontbs87 is offline   Reply With Quote
large geometry, mesh, mixing tank
3D mixing tank using MRF/SRF cfd_confuse Main CFD Forum 1 September 13, 2016 02:43
how to start for modelling n meshing a mixing tank with impeller jeevan ANSYS Meshing & Geometry 9 July 16, 2013 07:06
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
Mass conservation problem in mixing tank multiphase simulation rockewan FLUENT 0 April 6, 2010 12:34
What method use to modelate a side-entry impeller in a large scale mixing tank? fcabrales Main CFD Forum 0 January 29, 2010 14:24
