Home > Forums > FLUENT
"WARNING: no face with given nodes."
Like Tree1Likes
  • 1 Post By lordvon
Old   April 22, 2011, 10:29
Default "WARNING: no face with given nodes."
Robert
lordvon is on a distinguished road
I am trying to export a Fluent mesh from Pointwise. It is 2D, so no blocks, just domains. When I read it into Fluent, it does not read in properly due to the error message in the title. Has anybody encountered this error? I can export as CGNS and other formats and the mesh reads in fine. I want to read in as Fluent format (.cas) because all the boundary conditions are defined already in Pointwise and CGNS, etc. does not preserve that. Also, I do not want to manually seperate (which I have yet to get to work properly) and define all of the faces (2D lines in this case).
lordvon is offline   Reply With Quote
Old   April 22, 2011, 11:01
Default Aha!
Robert
So it appears Pointwise ignores/doesnt make visible the connectors (lines) in between domains in the exported fluent file, and fluent needs to see these connectors. In pointwise, you have to manually make connectors selectable (a checkbox when you pull up the window to set boundary conditions) and put them in an (unspecified) boundary condition group.
cm_jubayer likes this.
Old   April 23, 2011, 05:01
henry_lu
henry_lu is on a distinguished road
I had encountered such an error message ,when i tried to read a cas file into fluent, but not for the reason as your description. the reason may be that the cas file had been saved after unsuccessfully reviewing dynamic mesh.
henry_lu is offline   Reply With Quote
Thread Tools
Trackbacks are On
Import netgen mesh to OpenFOAM hsieh Open Source Meshers: Gmsh, Netgen, CGNS, ... 32 September 13, 2011 05:50
BlockMeshmergePatchPairs hjasak OpenFOAM Native Meshers: blockMesh 11 August 15, 2008 07:36
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
