April 23, 2011, 05:23 |
(PLEASE HELP) Error Y+ adaption
wibi ario
Rep Power: 15 |
i'm simulating butterfly valve with pipe. my simulation has converged but i cannot adapt it (i use y+/y* adaption) because i get an error message warning ST malloc : out of memory resize storage on thread. what should i do guys maybe anyone have same problem with me and give me a solution..please share in here. it's really urgent friend!
i use single computer ( dual core , 4GB of RAM, 1 tera of harddisk) |
April 23, 2011, 06:34 |
Rep Power: 16 |
how many elements does your mesh has?I think it's possible that you don't have enough RAM.
April 23, 2011, 07:43 |
wibi ario
Rep Power: 15 |
my initial mesh number is just 70.000 and after i adapt it 3 times then the cell increase significantly..it's about 1.150.000 cell. what should i do?
April 24, 2011, 07:39 |
wibi ario
Rep Power: 15 |
somebody please help!!!do not just read please!
May 5, 2011, 14:37 |
Casey
Rep Power: 16 |
sincity, 1,500,000 cells is a lot. You may be at the upper limit of what your computer can handle. I would suggest trying to re-mesh in gambit. Use the boundary layer options to make the boundary finer near the wall, but not everywhere. That way you may be able to get the y+ you are looking for, but not max out your memory.
the other thing you should try is running the code on a computer with more memory. I have dual core with less RAM and I can run simulations on the order of 500,000 but haven't gone to O(10^6). first re-mesh in gambit, get the cell size as small as you need just at the wall. |
May 10, 2011, 04:32 |
wibi ario
Rep Power: 15 |
my model has curvature geometry and a couple of small gaps its hard to make a boundary layer...if i could i would..
Mesh Adaption in CFX. | Kushagra Mittal | CFX | 1 | August 31, 2011 08:17 |
Adaption Error | Ken Adams | FLUENT | 0 | July 24, 2007 22:29 |
boundary adaption with geometry based adaption | Kate | FLUENT | 0 | October 9, 2005 10:44 |
On Gradient Grid Adaption | David | FLUENT | 2 | May 2, 2005 15:50 |
Need help with Grid Adaption | _stephen_ | FLUENT | 0 | January 13, 2005 07:07 |
