April 24, 2011, 13:23 |
arguement error with improper list. pls help
raymond
Rep Power: 16 |
I am defining properties of new fluids by user defined function which have later been interpreted into fluent without any problems. I am further defining the properties of mixture which consisting of those new defined fluids by user defined mixing law by compilation into fluent without any problems too. However, error appears after case file has been saved and been reloaded with fluent. Error message showing that there is error in arguement with improper list. I do not understand what's wrong with my setting. Please help me. It is urgent. Thanks a lot for help. Please help.
April 26, 2011, 07:54 |
arguement error improper list pls help.
#2 | |
Engr Adeniyi
Rep Power: 16 |
Please respond if it works (or not) for you and what you did. |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Read inside a class | tonyuprm | OpenFOAM | 12 | July 14, 2010 02:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
