Aluminium<solid> to Aluminium <liquid> conversion in material panel |
April 17, 2011, 12:14 |
zino
Rep Power: 16 |
Hi!
I m facing a problem in defining aluminium liquid at high temperature through Material panel in FLUENT. can anyone have idea? what if i define new properties by overwriting water<liquid> but viscosity in that case is unknown.so, in that case should i take water's viscosity? |
April 22, 2011, 09:25 |
Re:
Rep Power: 15 |
I am assuming the viscosity of water is going to be much less than what you would want to simulate for viscosity of molten aluminum. You should probably look up material property tables for molten aluminum that give you a value of viscosity in the temperature range you are interested in (might be difficult to find). Even if you were to find a an equation for viscosity as a function of temperature, you could and probably should implement it using a UDF.
April 25, 2011, 11:02 |
searched
zino
Rep Power: 16 |
Thanks for replying svp
yes. it is Last edited by zino; April 25, 2011 at 11:31. |
April 25, 2011, 11:04 |
#4 | |
zino
Rep Power: 16 |
Yes I searched a lot and it seems i have to put some supposed value. should I take value for liquid water as alumina liquid? Last edited by zino; April 25, 2011 at 11:32. |
aluminium, material, material properties |
why can't I delete aluminum in Material panel | sean | FLUENT | 11 | April 7, 2024 11:26 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
physical properties in material panel. | NEIL | FLUENT | 0 | April 26, 2007 14:30 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
