-   FLUENT (
-   -   [help Beginner]calculation error (
pirami May 2, 2011 00:58
the followings are the error messages I got
global courant number is greater than 250.00
the velocity field is probably diverging.
Please check the solution and reduce the time-step if necessary.
i'm trying to solve two-phase flow inside a cylinderical tank which has
water jet inlet.
i've tried several models but i got the same message.
FLUENT cannot calculate even one iteration.
help me.
xaero May 3, 2011 09:56
you need to provide more details of your case,
steady/transient? vof? explicit? what time step?
ximik May 4, 2011 16:41
I know this is obvious, but did you try reducing the time step? it will converge slower but it should be more stable.
