[help Beginner]calculation error
Old   May 2, 2011, 00:58
Question [help Beginner]calculation error
Jang Mingi
pirami is on a distinguished road
the followings are the error messages I got
global courant number is greater than 250.00
the velocity field is probably diverging.
Please check the solution and reduce the time-step if necessary.
i'm trying to solve two-phase flow inside a cylinderical tank which has
water jet inlet.
i've tried several models but i got the same message.
FLUENT cannot calculate even one iteration.
help me.
pirami is offline   Reply With Quote
Old   May 3, 2011, 09:56
xaero is on a distinguished road
you need to provide more details of your case,
steady/transient? vof? explicit? what time step?
greetings
xaero is offline   Reply With Quote
Old   May 4, 2011, 16:41
ximik is on a distinguished road
I know this is obvious, but did you try reducing the time step? it will converge slower but it should be more stable.
ximik is offline   Reply With Quote
courant number, diverging, fluent, two-phase flow
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
