-   -   Fluent Display is Black (http://www.cfd-online.com/Forums/fluent/88074-fluent-display-black.html)
shookybal May 7, 2011 14:56
1 Attachment(s)
Hi guys
Just started using fluent 12.1 after installation.
running windows 7 and having an intel graphic card.
I followed the 'elbow-workbench' tutorial and on the setup page all i can see in the display is black screen, no matter what i choose.
attached screenshot
hope you would be able to assist me (i need to do a my student graduation project)
thanks
shooky
litterfree May 9, 2011 08:16
Originally Posted by shookybal (Post 306630)
Hi guys
attached screenshot
thanks
shooky
you can try to set backgroud color in the "view" menu
shookybal May 9, 2011 09:21
thanks for your reply. how can i do that?
litterfree May 9, 2011 10:29
display->options->color scheme(select "workbench", not "classic")->apply.
done . try it.
shookybal May 9, 2011 12:07
still black.. any other ideas? maybe it has to do with the graphics driver?
I updated it and seems nothing has changed.
Its weird since the display works perfectly in the geometry, meshing and results cells..
thanks
litterfree May 9, 2011 20:13
in my computer, the method i write above works well, i have tested.
litterfree May 9, 2011 20:18
i dont know how to post the pictures . you write your email address down, i will send the pictures to you . in the two pictures you can see
workbench----blue background
classic-------black backgroud
coondason May 29, 2011 18:25
I have the same problem, and i tried the view solution and it
doesn't work.
Shooky, did you find a solution?
Thanks
sannyace June 12, 2012 03:48
doesn't work.
Thanks
did you get a solution for this problem? what is it as i have the same issue:eek:
sannyace June 18, 2012 05:09
solution found
reinstalled NVIDIA driver version 266.71 and black, background in fluent is history
Chika_3045 September 13, 2012 05:53
done . try it.
it works for me. Thanks!
