May 7, 2011, 12:26 |
Why fluent active ENERGY model?
Sylnet
Rep Power: 14 |
Why when I use the Species model with species transport fluent active the energy model? I have a box with 2 inlet and 1 outlet. In to the 2 inlet I put 2 different fluid but with the same temperature. If i have 2 fluid with the same temperature i think that I don't need a Energy model!
Thankyou |
May 9, 2011, 03:49 |
litter
Rep Power: 14 |
when you use the Species model the energy equation will active automatically . if you do not want to solve the energy equation, you can deselect the energy equation in the "solution panel" .
or select "volume-weghted-mixing-law" algorithm for density in the "material panel" for mixture material
never ever give up |
May 9, 2011, 05:27 |
Sylnet
Rep Power: 14 |
Ok, thankyou! But if I have a energiy equation actived or not the option "volume-weghted-mixing-law" it's always actived. If I want to simulate a mixing of two different fluid with a same temperature in a box, is it important that to have a energy equation actived?
Thankyou |
May 9, 2011, 07:47 |
#4 | |
litter
Rep Power: 14 |
i think, you are not need to solve the energy equation. so you can save some computation time and resouce hope you can understand my words, my english is poor. i want to learn
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Diff bet total energy & thermal energy model?? | vijeshjoshi23 | CFX | 5 | October 9, 2009 10:31 |
diff bet total energy model and thermal energy model?? | vijeshjoshi23 | Main CFD Forum | 0 | October 8, 2009 02:29 |
free sw to model ocean wave energy device? | Allen | Main CFD Forum | 0 | August 31, 2009 16:59 |
Why FVM for high-Re flows? | Zhong Lei | Main CFD Forum | 23 | May 14, 1999 13:22 |
