Boundar condition for pipe flow
I am beginner in CFD. I need some help, how to take into consideration the effect of the gravity in vertcial pipeflow (upward flow).
Thanks. |
i guess u can easily set gravity in operating conditions
Yes that where i need help, do i check in gravity and make -9.8m2/s ... aldo do i need to check in operating density and what vale, I am simulating vertical pipe flow of water
it depends on ur coordinate system, if ur vertical axis goes up positiv, then jes -9.82 m/sē ..... and this density checkbox u can ignore for water in my opinion
hope i could help u |
Thanks shimmyya for your reply. Yes my cooridnate system is +y upwars i.e. I have taken my reference coordinates (0,0,0) at the top of the pipe.
As I understand I do need to check in the gravity option box and do not need to fill the operating density ... but by default it shows a value of 1.225 .. shoud I make this zero or someother value as far i understood the value subsituted here will be subtracted from fluid density i.e. [rho(fluid) - rho(op density] g.h? waiting for your reply. Thanks once again |
hi,
just let this "specified operating density" box unchecked, that should be fine. |
Need help, can you plz help ... how to calcuate the pressure drop in pipe flow ... can't seem 2 understand the Fluent output plots .. as values I have do not come anywhere near.
i dont know if this help u , but u can set probe-points which can read out the data of this points like pressure, velocity ......
could be also good to know what version of FLUENT u use |
