-   FLUENT (
-   -   k-e convergence criteria (
aras May 19, 2011 23:53
I am solving a turbulence flow inside a pipe with many steps, complexities including lots of walls.
I am getting good convergence (below 1e-3) for velocities, and continuity.
but k and e are fluctuating in the range of 1e-2, is it ok? and generally what is the satisfactory range of convergence for k and e?
alastormoody11 May 20, 2011 06:29
Have you checked the validity of your mesh for using the k-e model, check whether the wall y plus values are in accordance with the recommended values suggested in the FLUENT manual.
I think the default values for the residuals are good enough. I would not recommend that you use unconverged results.
aras May 20, 2011 08:53
so, do you know what are the recommended y+ in fluent for k-e?
swiftaircraft May 21, 2011 08:44
This is clearly specified in the help files provided with Fluent
