Can fluent get the lift and drag coefficients of the two walls (in different directio
Old   January 8, 2014, 05:59
Default Can fluent get the lift and drag coefficients of the two walls (in different directio
yu. yuxuan
yuyuxuan is on a distinguished road
There are two walls wall1 and wall2.
wall1 z-axis direction, wall2 x-axis direction.
I use {monitor-force}. After the calculations and I found that only get wall2 lift and drag coefficients. That means when I set, the wall2 settings cover the previous settings
so I want to know can fluent get the lift and drag coefficients of the two walls , thank you.
yuyuxuan is offline   Reply With Quote
Old   January 8, 2014, 07:48
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Define 2 monitorings: one for wall1 and one for wall2
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 8, 2014, 19:09
yu. yuxuan
I use the Fluent 6.3.26. And in the GUI, I cannot find the {Define monitor number}. Where is it, and thanks for replying.
Old   January 9, 2014, 00:45
-mAx-'s Avatar
Maxime Perelli
Monitoring Forces and Moments on Individual Walls
By default, FLUENT will compute and monitor the total force or moment for all of the selected walls combined together. If you have selected multiple walls and you want to monitor the force or moment on each wall separately, you can turn on the Per Zone option in the Force Monitors panel. The specified force vector or moment axis will apply to all selected walls. If the monitor results are printed to the console (using the Print option), the force or moment on each wall will be printed in a separate column. If the results are plotted (using the Plot option), a separate curve for each wall will be drawn in the specified plot window. If the results are written to a file (using the Write option), the file will be in a tab-separated column format based on the XY plot file format described in Section 28.8.5.
https://www.sharcnet.ca/Software/Flu...049.htm#179853
Old   January 9, 2014, 05:07
yu. yuxuan
By default, FLUENT will ......
I see the links, but there is a problem that:
The lift direction of wall1 is z-axis .
while the lift direction of wall2 is x-axis .
So if I choose two walls, it shares the same force direction,right? Then if I put (0,0,1) in {Force vector} . Does it change the force direction of wall2 into z-axis?
Old   January 9, 2014, 07:17
-mAx-'s Avatar
Maxime Perelli
ok I understand
Then you can try to define 2 monitors by clicking "Apply" once one monitor is well set
Remember to click Apply after making the desired modifications to the setup for each coefficient report.
Old   January 10, 2014, 06:29
yu. yuxuan
ok I understand
I try but it still only get the wall2 data.
Old   January 10, 2014, 06:58
-mAx-'s Avatar
Maxime Perelli
then I don't know since I don't have Fluent
Old   January 10, 2014, 20:13
yu. yuxuan
, Thank you for your kind help
fluent 6.3.26, lift and drag, two geometries
direction vectors for lift and drag in fluent nauman55 FLUENT 7 September 23, 2020 14:47
calculating drag and lift in fluent morteza08 FLUENT 4 December 13, 2012 15:34
Great lift coefficients but negative drag coefficient?! nez FLUENT 0 November 28, 2011 13:57
How does FLUENT calculate lift and drag? xTamx420 FLUENT 0 May 30, 2011 13:35
Lift and Drag Coefficients Reliability Luis FLUENT 2 December 27, 2005 14:45
