Boundary condition using .prof file
Old   May 24, 2011, 08:04
Default Boundary condition using .prof file
Siddharth
sidzishere is on a distinguished road
Could someone guide me as to how the boundary condition for the a non uniform pressure profile can be set using the profile option. I need guidance as to how to write the .prof file.... Is it possible to create profiles in CFX and import them and read them in fluent as a boundary profile.
sidzishere is offline   Reply With Quote
Old   May 24, 2011, 15:31
MadhuVC
madhuvc is on a distinguished road
I am not sure about importing the profile file from CFX, but I believe if you can change the CFX file to a *.prof file, without messing up with the fluent profile file structure, I guess this should be possible.
Generating a profile file within fluent.. Select Boundary Condition --> Profiles -->Write--> Define new --> Select zone on the left and parameter on the right.
write this as a *.prof file. Open the file with a text editor and you should be able to add values to your profile.
If you need more information, please refer
Reading and Writing Profile Files in User Guide Section 4.6
madhuvc is offline   Reply With Quote
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
