Post processing images
Old   January 13, 2011, 18:27
Default Post processing images
Patrick Young
Mudblood is on a distinguished road
I want to display my model with some particle tracks and save an image.
I know that it's possible to display my mesh so that it looks solid, and not like a mesh. How is this done? The search engine was no help as I don't know what the keyword for it is
Thanks
Mudblood is offline   Reply With Quote
Old   May 24, 2011, 15:55
Default Re
svp
svp is on a distinguished road
Could you let me know if you had found out the answer for this question? I want to do something similar.
Thanks.
svp is offline   Reply With Quote
Old   May 24, 2011, 16:09
MadhuVC
madhuvc is on a distinguished road
probably u might want to play with scene under graphics and animations. You can make the mesh transparent and change the colors and things like that.
madhuvc is offline   Reply With Quote
Old   May 24, 2011, 16:11
svp
Thank you for your reply. I have been experimenting with that a little bit, but haven't come across a combination that works as yet. Could you be more specific with regards to the options that I might try? Thanks.
Old   May 24, 2011, 16:21
MadhuVC
I assume you are able to select zone x in your scene tab and then get into the edit mode, where you see face color on the right, some task bar below it and face, edges on the left.
I usually select the faces, outer faces, lighting and deselect the edges and perimeter lines (basically lines).. then drag the transparent bar to around 30-50 (depending on what you want) and change the color. you should be able to have the solid kind of mesh instead of a wire mesh. hope this helps.
post processing for KIVA dirga Main CFD Forum 5 April 23, 2009 10:58
Question about post processing qtian OpenFOAM Post-Processing 0 July 24, 2007 12:44
Tecplot for CFX post processing pantangi goud CFX 2 August 24, 2005 16:42
A question about .eps images using CFX5.6 post Forrest CFX 6 June 18, 2004 03:24
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
