-   -   Inertial Resistance and Viscous Resistance Data (http://www.cfd-online.com/Forums/fluent/88779-inertial-resistance-viscous-resistance-data.html)
ravitejakatragadda May 25, 2011 18:09
I am modeling the grille and radiator in the under hood of a car using Ansys FLUENT on Ansys Workbench. I modeled grille and radiator as porous media (In addition radiator is modeled as heat exchanger). The user inputs required for porous media are inertial resistance factor and viscous resistance factor. For that I need to have experimental data of Velocity and Pressure Drop across the porous component (Grille and Radiator in this case)
Could anyone recommend values for the
1. Inertial Resistance Factor
2. Viscous resistance Factor
(Or)
Provide any experimental data for Velocity Vs Pressure Drop for the two components.
Any help in this regard is appreciated.
m zahid September 24, 2014 07:06
hi
hi, have you find answer ? i want to know about the method of finding inertial and viscous resistance for modeling vegetation as porous media.if you have some material or link please share with me .
thanks
NgoIchSon July 12, 2016 03:36
I am studying on multiscale CFD simulation of carbon fiber impregnation process by thermoplastic matrix.*
In Brinkman equation: dp/dx = (mu/k)u + beta*rho*u*u, the first term on the right hand side is Darcy or viscous component, while the second term is non-Darcy component. The viscous resistance is 1/k where the beta is inertial resistance.*
According to several refs. such as*Higdon, J. J. L., & Kojima, M. (1981);*Dake, L. P. (1983), the non-Darcy is negligible at low flow velocities and generally omitted from liquid flow equations. Thus, taking into account the inertial term is depend on your flow (gas or liquid, fast or slow)
In Fluent, you can estimate the viscous resistance by Ergun equation (Fluent theory guide) which related to unit length and porosity of your porous media geometry:
Viscous resistance: 1/K = (Dp*Dp/150)*(epsilon^3)/(1-epsilon)^2
Inertial resistance: C2 = 3.5/Dp*(1-epsilon)/(epsilon^3)
where Dp is mean diameter of particles in porous media, epsilon is porosity.
In addition, you also can apply Forchheimer equation for flow through fibrous porous media by replacing Dp by sqrt(K) in C2 equation.
Regards,
Son
Refs:
Dake, L. P. (1983). Fundamentals of Reservoir Engineering: Elsevier Science.
Higdon, J. J. L., & Kojima, M. (1981). On the calculation of Stokes' flow past porous particles. International Journal of Multiphase Flow, 7, 719-727.
