Gambit create blend
Old   June 3, 2011, 05:31
Default Gambit create blend
guney
guzeydogy753 is on a distinguished road
Hello,I have a problem about blend real volume.I have blade of stator and on the bottom of this stator I have cylindric bottom it means that I have 2 volumes and I want to blend intersection of blade and cylindric bottom with radius 30 or sth like that.But if I try I get the error 'a blend may not be set on a boundry of a sheet metal body'.Please help me thank you very much
guzeydogy753 is offline   Reply With Quote
Old   June 6, 2011, 01:49
-mAx-'s Avatar
Maxime Perelli
a picture may help
Old   June 10, 2011, 09:43
guney
this fillet betweeen blade bottom and assemble of main part
Old   June 10, 2011, 09:51
-mAx-'s Avatar
Maxime Perelli
repost a picture with zoom on volumes which give you trouble.
Use also color label to identify volumes in your explanation.
Which tool did you used to blend your volumes (unite-merge?)
Old   June 10, 2011, 10:15
guney
I dont want to use tool for fillet. I want to do it in Gambit solid body maybe the command is real blend volume but I dont know how to do it. when I try to do it I get errrors ''a blend may not be set on a boundry of a sheet metal body''.PROJE.jpg
Old   June 14, 2011, 01:54
-mAx-'s Avatar
Maxime Perelli
I still don't understand what you want to do.
Can you provide your dbs file?
Help! Gambit cannot blend edges Wencai Main CFD Forum 2 December 10, 2008 03:24
How to create *cas file from Gambit? Sandra FLUENT 2 October 4, 2007 17:46
Creating geometry & meshing using Gambit Ray FLUENT 3 August 1, 2000 03:30
GAMBIT and Turbomachinery tom Main CFD Forum 6 October 21, 1999 09:50
