Semi - transparent material emissivity properties |
September 1, 2023, 02:07 |
Gopalakrishna
Q. How can I give different transmissivity with more than 3 wavelength region?
I used Discrete Ordinates (DO) Model since it is the only model with 'semi-transparent' and 'non-gray' mode. I want to give material A (semi-transparent) transmissivity or emissivity like this: ex) t=0.75 in 0 to 4 µm, or e = 0.25 t= 0.75 in 4 ~8 µm, or e = 0.25 t=0.75 in 8~14 µm, or e = 0.25 t = 0.0001 in 14 – 1000 µm, or e = 0.9999 (t is transmissivity), e = emissivity. But when I change BC type of a material A from opaque to semi-transparent in boundary condition - radiation tab, I made four bands, 0 – 4, 4 – 8, 8-14, 14-1000 µm in Model - Radiation - Number of Bands, but I could only change Direct / Diffuse Irradiation and Diffuse Fraction of each band, not transmissivity or emissivity of each band. Please, someone can guide me, it would be a great help, Is it possible to give each band different emissivity? |
How to introduce solid material and its properties at wall? | wassli | STAR-CCM+ | 3 | February 22, 2017 16:01 |
Checking UDF material properties | salumi | FLUENT | 0 | December 2, 2016 05:57 |
material properties of solid parts are constant ? | oozcan | FLUENT | 0 | August 2, 2016 06:04 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
Material Properties table? (function of two variables) | evcelica | CFX | 2 | October 1, 2012 19:36 |
