-   -   Problem with buoyancy driven in enclosure (http://www.cfd-online.com/Forums/fluent/89477-problem-buoyancy-driven-enclosure.html)
Asghari_M June 14, 2011 03:01
Hi all;
I'm simulating of a cubic closed water Tank (enclosure) in a buoyancy driven (Natural Convection) manner. This tank is heated by an electrical element located on beneath(below) plane as Temperature of this below plane is always 350 (kelvin) whereas upper plane temperature is in the ambition condition (300 kelvin) and cooled by ambient. Also, side walls are insulated. So, natural circulation occures into the water enclosure.How can I resolve this problem? I used a piecewise-linear for water density definition to be considered buoyancy force, but the results that I took, seem not to be logical and even those diverged in some cases!:(
Thanks a lot for any suggestion and advise to be treat this problem.
alessandro.zomparelli June 14, 2011 04:45
Hi Asghari_M,
I'm only a newbie, but maybe this can help you:
http://my.fit.edu/itresources/manual...f/tg/tut05.pdf
cheers
Asghari_M June 14, 2011 05:25
Hi alessandro;
That's good. I read it beforehand. However the fluid in that tutorial is air and air density follows boussinesq approximation in that problem. But, My working fluid is water and I use piecewise-linear approximation for the calculation of water density. Should I use boussinesq approximation for the calculation of the air density? I would be appreciated if you give me some the guidelines to be resolved these problems.
Thanks a lot for any suggestion, too.
alessandro.zomparelli June 14, 2011 05:34
I'm so sorry, but I use CFD only like a support for my job: Architecture. I do not have the necessary knowledge to give you a more specific help :(
Asghari_M June 14, 2011 07:02
Thanks again Mr.Zomparelli;
However, I 'll welcome for anybody coming to our discussion and giving further suggestion for presenting a basic solution, because the problem has not been still resolved.:(
Asghari_M
Laci June 14, 2011 07:46
This should work.
Try with the following settings:
Presto! for Pressure; Second O. Upwind for Momentum and Energy.
skullCFD June 14, 2011 17:19
You can use Boussinesq approximation for water. Even otherwise, some of the ways to deal with free convection in water are:
1. to first solve a pure conduction problem and then use it as initial guess and apply free convection.
2. to solve a transient problem first and use it as initial guess for the steady simulation.
Asghari_M June 18, 2011 01:27
Hi Dears;
I examined Boussinesq approximation, S.O discretization for energy solving and a transient solution for my problem, dT=0.01. Nevertheless, Spite of these settings , the solution isn't logical, yet:(. Really, this problem seems to be simple to solve. However when solving residuals for continuity and vector velocities aren't logical, yet. What should I do? Can air as a material help for checking the settings ?
If necessary, I can attach my figures in next message. Also, for more precise results, you can discuss with me more via this email address: mehdiasgh@gmail.com .
Thanks a lot for any suggestion, again.
Asghari_M June 20, 2011 03:58
Also, I think that this problem is in the turbulent regime since Grashof number is about 4.54E+11 (turbulent regime starts in grashof number approximately 56000). Is there a method for solving this problem by turbulent modelings?;)
myty June 12, 2013 00:02
When u r simulating Natural convection, water density is given by boussinesq, and also first start running simulation with small value of gravity "g" and then go towards 9.8, start with standard pressure solver and after first convergence change pressure solver to body force weighted. I hope it will work.
