November 10, 2022, 06:39 |
Merging Cell zones in Fluent Meshing
Moe
Rep Power: 4 |
I am trying to simulate flow over buildings where I also have multiple trees. I am using Fluent meshing for mesh but the problem is that I want to merge the cell zones for the trees so I can define its properties one-time in Fluent, and also so that I don't get a lot of internal walls (my simulations has hundreds of trees) When I try to merge cell zones in Fluent meshing I get the message (Selected regions cannot be merged, none of them share face zones) I guess because they are not touching each other. I could do this before, but I used a STEP cad file and used usual Ansys meshing (trees were separate but defined as one solid in Autodesk Inventor) Now I'm using Spaceclaim for geometry which cant merge untouched bodies and also using Fluent meshing which cant define named selection as regular Ansys mesher. Any help or idea is greatly appreciated |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
Neighboring cells in tetrahedral mesh | vishwesh | OpenFOAM Programming & Development | 9 | November 10, 2017 07:06 |
Building problems with cell zones when reopening Fluent | MJ2017 | FLUENT | 0 | October 14, 2017 08:11 |
Separating Cell Zones in ICEM or Fluent | dbarre5 | Mesh Generation & Pre-Processing | 0 | July 12, 2017 13:41 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
