Mesh Independent Problem
Old   June 16, 2011, 01:29
Default Mesh Independent Problem
ZenCef
ZenCef is on a distinguished road
Hi Guys,
I've a convection problem between wall and tube. There are three solids contacting eacg other. I've adapted contacting surfaces. There are concection boundry condition on both side of wall and inside of tube. For the same B.C. the reference temperature on the pipe and heat flux through the interface are rising with element number. I think element number should be sufficient. I attached model and the results according to node number, what could be my mistake ?
ZenCef is offline   Reply With Quote
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Moving mesh problem Geon-Hong FLUENT 3 April 5, 2010 03:24
mesh generation problem Ellen FLUENT 7 February 18, 2009 21:20
