Home > Forums > FLUENT
UDF problem
Old   June 20, 2011, 09:43
Default UDF problem
Herman
Rowing is on a distinguished road
Hello
I was wondering if someone could help me out.
At the moment I have the CG_MOTION udf and specifying velocity as
vel[0] =1. I need the velocity to travel to the end of my domain and then to reset to the begin point and travel again and again and so on
can someone please help me with this???
I also have to define the interaction of air and water. For this using the vof model. When I do it as the tutorial say I gat the whole domain as either water or air but not a defined line between the two?? Can someone please help me?
Thank you
Rowing is offline   Reply With Quote
Old   June 30, 2011, 10:38
Adrien Lemoine
AdrienL is on a distinguished road
I don't really get the first part of your question but for the second part you can use the Adapt --> Region to mark a region that will be filled with water.
After initialization you can use the patch option, you have to choose the 2nd fluid material and patch it on the region you just created (under registers to patch)
Adrien
Plz add reputation if the answer is correct
A cur vaillant rien d'impossible
AdrienL is offline   Reply With Quote
Thread Tools
Trackbacks are On
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 32 May 8, 2015 06:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 01:31
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 10:58
