June 28, 2011, 10:42 |
0 or 0.0 in udf
raymond
I would like to write an udf and i referred few of the samples. I confused with the value of "0 and 0.0". Can pls help in making them clear?What are the differences between them?Pls help.
Best regards |
June 29, 2011, 12:34 |
Micael
Rep Power: 18 |
It is not about FLUENT nor much about zero, but about the C language. Lets see an example:
real c; c = 1/2; In any case, you should be aware of that rule. One remedy is to simply add ".0" after at least one number, so that arithmetic will be done on real instead of integer (any integer in the arithmetic will be promoted to real before the calculation): Code:
real c; c = 1/2.0; |
June 29, 2011, 13:39 |
#3 | |
raymond
Thanks Micael. You totally help me a lot. May I have one more question? Is the result of c=1.0/2.0 or c=1.00/2.000 similar to c=1/2.0? I wrote udf and not sure whether was it correct or not. Can pls help to a look on it? Thanks a lot. DEFINE_PROPERTY(acetic_acid_density, c, t) { real C; /* self-defined variable for convenience */ real D; /* self-defined variable for convenience */ real rho; /* calculated density in unit kg/m3 */ real T = C_T(c,t); /* temperature in unit kelvin, K */ const real A = 0.35182; /* dimensionless regression coeficient */ const real B = 0.26954; /* dimensionless regression coeficient */ const real n = 0.26843; /* dimensionless regression coeficient */ const real Tc = 592.71; /* critical temperature in unit kelvin, K */ C = 1-T/Tc; /* self-defined variable for convenience */ D = pow(C, n); /* self-defined variable for convenience */ rho = A*(pow(B, -D))*1000; /* calculated density in unit kg/m3 */ return rho; } DEFINE_PROPERTY(acetic_acid_viscosity, c, t) { real E; /* self-defined variable for convenience */ real mu; /* calculated viscosity in unit kg/m.s */ real T = C_T(c,t); /* temperature in unit kelvin, K */ const real A = -3.8937; /* dimensionless regression coeficient */ const real B = 784.82; /* dimensionless regression coeficient */ const real C = 0.006665; /* dimensionless regression coeficient */ const real D = -0.0000075606; /* dimensionless regression coeficient */ E = A + B/T + C*T + D*T*T; /* self-defined variable for convenience */ mu = 0.001*pow(10, E); /* calculated viscosity in unit kg/m.s */ return mu; /* calculated viscosity in unit kg/m.s */ } DEFINE_PROPERTY(acetic_acid_thermal_conductivity, c, t) { real C; /* self-defined variable for convenience */ real D; /* self-defined variable for convenience */ real E; /* self-defined variable for convenience */ real ktc; /* calculated thermal conductivity in unit W/m.K */ real T = C_T(c,t); /* temperature in unit kelvin, K */ const real A = -1.2836; /* dimensionless regression coeficient */ const real B = 0.5893; /* dimensionless regression coeficient */ const real Tc = 592.71; /* critical temperature in unit kelvin, K*/ const real n = 2/7; /* dimensionless regression coeficient */ C = 1-T/Tc; /* self-defined variable for convenience */ D = pow(C, n); /* self-defined variable for convenience */ E = A + B*D; /* self-defined variable for convenience */ ktc = pow(10, E); /* calculated thermal conductivity in unit W/m.K */ return ktc; } Thanks to have a look. Your opinion will be appreciated. Best regards |
June 29, 2011, 14:45 |
Micael
Rep Power: 18 |
Yes, all the same. It can be put more compact like this:
c=1./2; Code:
const real n = 2/7; /* dimensionless regression coeficient */ Otherwise your code looks good. |
June 29, 2011, 16:03 |
#5 | |
raymond
What are the differences between real and const real?Can I just put real n=2./7, instead of const real n=2./7? Best regards |
June 29, 2011, 17:27 |
Micael
Rep Power: 18 |
const means it is not modifiable after declaration. It does not really add something usefull in the present situation.
DieselFoam spray | thumthae | OpenFOAM Running, Solving & CFD | 98 | December 24, 2014 16:55 |
Correction of KIVA ITAPE | hama | Main CFD Forum | 1 | December 2, 2011 14:47 |
[snappyHexMesh] Giving patch names within stl files | Nik_ | OpenFOAM Meshing & Mesh Conversion | 2 | October 27, 2010 14:41 |
STONE'S STRONGLY IMPLICIT SOLVER | anybody | Main CFD Forum | 8 | August 18, 2006 11:01 |
correction of KIVA Itape | hama | Main CFD Forum | 0 | May 2, 2006 04:41 |
