June 30, 2011, 10:33 |
Quick tip to obtain negative convection
Hello there !
In order to compute the residual lifetime of air (in a RANS steady-state case of ventilation efficiency), I need to reverse the velocity field (hence what can be called a negative convection). I'm sure it's doable using UDFs but right know I export velocity data, reverse values under Excel then re-import it under Fluent. My question is do you see a quicker way to do this in Fluent (no more Excel) or the only way out is to merge an UDF ? Thanks in advance |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 02:39 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Contour plot with negative velocity | J | CFX | 11 | November 3, 2008 16:46 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
