error message "-1.#IND"
Old   April 7, 2013, 16:27
Default error message "-1.#IND"
bbasal is on a distinguished road
i have specified boundary conditions and values (for example 1 m/s for velocity inlet) and have came to "solution initalization". i have select the boundary in the solution initalization to input again 1 m/s in the boundary but there is already a value which is "-1.#IND"
what is the problem
and is there an error box which identifies every error's meaning.
bbasal is offline   Reply With Quote
Old   April 8, 2013, 13:31
Mehrdad Mohammadian
mehrdadm_1989 is on a distinguished road
what is the problem
the minus of velocity depended on your coordinate system.for example if your flow direction parallel to x axis the velocity must be +.and if opposite you will see - value.
mehrdadm_1989 is offline   Reply With Quote
Old   April 9, 2013, 16:30
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Hi
Are you using UDF in your simulation? If yes, you defined a wrong formula somewhere something like "-1/0" or you've reached upper limit of data size to store a double or even it may rises due to a wrong math operation e.g. sqrt of a negative number.
Regard yours
A CFD free user is offline   Reply With Quote
Old   April 9, 2013, 17:04
Originally Posted by A CFD free user View Post
Hi
no, I am not using UDF.
is it imposible to simulate 2D vertical annuli flow.
I mean, inner tube the heat transfer fluid flow and the annulus gap air take place. i want to solve natural convection into air.
thanks for replies
