UDF for heat generation
Old   July 7, 2011, 06:22
Default UDF for heat generation
prince
prince_pahariaa is on a distinguished road
Hii all..
My problem has internal heat generation of around 15 KW. It is near the hemisphere present in my geometry. Problem is heat is not generated through out the hemisphere. It emerges through only part of it. While drawing in GAMBIT, the whole hemisphere is built once. So in fluent i am not getting any idea how to incorporate only half part of solid for heat generation. I guess through writing UDF it can be done. I am rather new to software and this is first problem which i am working in detail. Really need help on this one
Thanking u all..
prince_pahariaa is offline   Reply With Quote
Old   July 8, 2011, 05:47
Default divide the zone
prince
I was trying to solve my problem by using UDF concept. But its not working. I guess i need to go back to GAMBIT and construct the hemisphere in two parts so that i can create two zones. Or if i can able to divide the hemisphere into two parts in fluent itself, my work will become lot easier. I dont know how to do divide in fluent or m not sure whether it can be done or not.
Hoping some help here..
Thanks
Old   July 8, 2011, 06:38
Kristian Etienne Einarsrud
KristianEtienne is on a distinguished road
You can do the separation in fluent, no need to do the whole remeshing task or using a UDF.
First, you need to mark the region which contains one half of your hemisphere. Do this through the "Adapt -> Region" menu. Here you can give the coordinates of your region of interest. When you have given your coordinates, click on "Mark" to store this register. (Do NOT click on the "Adapt" button, as this is used to refine the mesh).
Next, go to "Mesh->Separate->Faces" Under options choose "Mark", under Registers, choose the register you created in the previous step, under "Zones", select the hemisphere which you want to separate. Click on "separate" and you will now have divided your hemisphere into two regions.
Good luck!
-KE
KristianEtienne is offline   Reply With Quote
Old   July 11, 2011, 02:36
Default Problem in finding "Mesh- Separate faces" option
prince
Thankss for the replyy..
Initially i ran into trouble in finding "Mesh-> Separate faces" option. Later i found it under "GRID->Separate Faces" option. I am going to follow the suggestion u have give. Hopefully it should work. I will let u know.
Thanks for the help..
Old   July 11, 2011, 02:58
Hello again,
Yes, some names on the menu where changed between versions 6.3 and 12, among others; "Grid" was changed to "Mesh".
Good that you found it anyways. Good luck!
udf for heat generation rate sarah l Fluent UDF and Scheme Programming 53 December 5, 2022 08:45
entropy generation with UDF mohammadkm Fluent UDF and Scheme Programming 22 June 10, 2020 22:37
Looking for UDF files of the tutorial "Simulation of Wave Generation in a Tank" seucj Fluent UDF and Scheme Programming 12 August 21, 2015 05:52
UDF for heat generation prince_pahariaa Fluent UDF and Scheme Programming 0 July 7, 2011 06:04
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 04:07
