how to compare unsteady state problem results from FLUENT with Experimental data? |
July 10, 2011, 08:25 |
Selvam S
HELLO EVERYONE,
I have made a concentric heat exchanger setup in which water flows through the inner tube and steam in the outer tube. I am trying to study change in heat transfer for various water flow rates. Several trials are taken with different water flow rates keeping steam flow rate constant at a pressure of 2 bar. Here steam serves to maintain a constant wall temperature. Now i am having trouble in modelling the same with Fluent since steam changes phase ( its in two phases ) as it passes along the length of the tube and should be treated as problem of unsteady state. How should i model this in fluent. Also how should i compare the experimental data ( conducted in steady state condition i.e. only the overall temperature increase is considered ) with Data from Fluent model of unsteady state. Thanks in advance. |
cfd, condensation, heat transfer, steady and unsteady state, two phase flow |
Comparison of experimental and CFD results for the VA-2 supercritical airfoil | Aurélien | FLUENT | 3 | Today 10:39 |
using steady state results for unsteady flow | siva appanna | Main CFD Forum | 3 | February 20, 2006 05:29 |
Simulated data vs. experimental data | moiami | FLUENT | 0 | December 19, 2002 01:03 |
PhD in turbulence | Hans | Main CFD Forum | 14 | October 8, 2001 03:03 |
