Why doesn't coarsening occur during grid adapting?
Old   February 9, 2007, 10:13
Default Why doesn't coarsening occur during grid adapting?
A. S.
Hi all,
I am running a complicated geometry with turbulence and trying to adapt my grid so that wall Y+ will fall into an acceptable range. To do this, I am using the Adapt menu feature to adapt by Wall Y+.
When I click Mark, the feature shows me that 0 cells need refinement and that a lot of cells need coarsening. When I click Adapt, however, nothing happens-- the same grid wrong grid is given as the output (0 change in cells, faces, etc).
I am working in a 3D geometry with tetrahedral cells (T Grid). I think that Fluent will only let me refine and not coarsen-- why is this?
Thanks in advance, AS
Old   February 9, 2007, 11:22
Default Re: Why doesn't coarsening occur during grid adapt
HSeldon
Hi, I think that coarsening only ocurrs with conformal adaption. Make sure that you have enabled that option in "Controls" menu. And also, I think that if the node/s you want to coarse is on a boundary Fluent won´t adapt it.
Hope this help!
Old   July 11, 2011, 17:00
John is on a distinguished road
Originally Posted by HSeldon
;139011
Hope this help!
Hi all,
It is true that refined mesh on boundary can not coarsen?
Thanks,
John
John is offline   Reply With Quote
Question on grid coarsening panos_metal FLUENT 0 October 10, 2010 11:19
Coarsening an original grid Azman FLUENT 1 January 18, 2006 05:40
negative grid volumes when adapting Dave FLUENT 1 August 20, 2005 13:47
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
