unsteady heat transfer model problem
Old   July 12, 2011, 23:26
Question unsteady heat transfer model problem
Beryl is on a distinguished road
I am having some problems of fluent to accurately model the following unsteady heat transfer model:
I have a fluid-solid interface problem: a steel pressure vessel (diameter:10mm, length:50mm) containing water and a thin metal wire(diameter:25um,length:30) put in the middle of the vessel. Heat is applied to the suface of the thin metal wire,then the heat transfer will cause natural convection of the water in the vessel.
however,after running the simulation with 100 time steps of approximate 4seconds,the temperature of the surface of thin metal wire increases linearly with time,but from my experiment the temperature should be increase lower and lower. And the residual of x,y velocity is no less than 10e-2,the residual of continuity is stable in 10e-3.
I am using the following conditions in fluent:
2D Axisymmetric Segregated unsteady 2st order Implict Solver, energy equation, laminar viscous flow, Boussinesq for density, PISO pressure-velocity,standard Pressure discretization, second order Upwind for Momentum and Energy.
Boundary condition: the same heat flux in solidwall(the thin wire surface) and solidwall-shadow. My boundary condition right?
Am i missing something? Any suggestions?
Thank you very much!
Beryl is offline   Reply With Quote
Heat transfer problem at nucleate boiling MrStuebb FLUENT 12 March 14, 2017 13:31
Heat Transfer convergence Problem mit a 1/6 compressor model chili023 CFX 1 January 15, 2011 06:41
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 17:31
facing problem in heat transfer coefficient dhiraj CFX 1 May 7, 2007 09:08
Electrolyte heat transfer problem fea user CFX 0 November 28, 2006 17:39
