July 13, 2011, 09:57 |
BCs in Fluent for flow inside a cylinder.
Miguel Graça
Good afternoon, I'm currently trying to model the reactive flow inside a closed cylindrical combustion chamber with circular/annular inlets and annular exhaust. The geometry is completely axisymmetric, and I've already done the calculations using a 2D mesh, but now I've been tasked with running the same case using a 3D mesh of a 30 degree section of the chamber.
My first question is about setting the appropriate boundary conditions: Is the axis boundary condition the correct one to use in this case? Ou would setting a symmetry BC on each of my side boundaries fix the problem? It would seem obvious to me that for a 90 degree section the symmetry condition would be okay, but not so for the smaller section I'm using. Secondly, using the same method I followed in ICEM to model the 2D case, I created a part in the 3D model corresponding to the axis of axisymmetry of the chamber. When reading the mesh in fluent, however, this does not show up in the boundary conditions tab, where I'd like to set it as an axis (assuming this would be the right way to do so, of course!) Any help at all would be much appreciated! |
FLUENT, flow past a circular cylinder | Paul Reichl | Main CFD Forum | 16 | December 8, 2012 15:21 |
drag coefficient of cylinder using fluent | john lynam | Main CFD Forum | 2 | February 15, 2010 09:16 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 15:16 |
cylinder grid for fluent | Wolfgang | Main CFD Forum | 1 | October 21, 2002 12:11 |
Pressure BCs in FLUENT | Julien | Main CFD Forum | 2 | May 13, 1999 20:16 |
