Laminar zone
Old   July 21, 2011, 10:32
Default Laminar zone
Freddy S
Freddy is on a distinguished road
Hello at all,
I have a problem evaluating a calculation I performed!
I am currently modelling a flow around a wing section. Due to low reynolds numbers, a laminar zone occurs. The laminar turbulent transition is well-known from experimental data. Simulating these experiments using a laminar zone (rest: k-e realizable), a comparably good accuracy occured (in lift as well as in drag).
Certainly, at huge angles of attack, the resulting maximum lift coefficient seems unrealistic (huge) due to huge feasible angles of attack before the flow separates. Modelling a turbulent flow (at same adjustments), lift coefficient is less due to less maximum angle off attack (turbulent separation at trailing edge).
Regarding pressure distribution, there is a difference, especially at the section of laminar zone.
Does anyone knows, why such a difference occurs.
Thanks
Freddy is offline   Reply With Quote
Old   July 22, 2011, 08:24
Raashid Baig
cfd_newbie is on a distinguished road
See this thread below it will give valuable inputs to your problem -
http://www.cfd-online.com/Forums/cfx...cted-lift.html
cfd_newbie is offline   Reply With Quote
Old   July 22, 2011, 08:34
neema
neemasheby is an unknown quantity at this point
Hi
I am new to this forum, new to CFD and also programming. My first cfd code was jos stam's fluid dynamics code. I came to know it's not a good code to simulate turbulent flow (or is there a way to introduce turbulence into it) . I came to know that RANS is one good method to simulte turbulent flow. It would be very helpful if you could suggest any basic RANS source code I can refer............. Please Help .......
neemasheby is offline   Reply With Quote
Old   July 22, 2011, 14:11
Nik
nikhil is on a distinguished road
@ Above - start with k-e model available in Fluent
nikhil is offline   Reply With Quote
Polynomial thermophysical properties and laminar porous Zone vemps OpenFOAM 0 June 30, 2011 10:13
Polynomial thermophysical properties and laminar porous Zone vemps OpenFOAM 0 June 28, 2011 10:22
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 08:42
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 15:52
