-   -   RNG k-e vs Standard (http://www.cfd-online.com/Forums/fluent/90910-rng-k-e-vs-standard.html)
CFDlearn July 24, 2011 19:06
RNG k-e vs Standard
is the RNG k-e model shows better performance than the standard k-e model in the prediction of heat transfer
Laci July 25, 2011 06:18
It depends on the flow. Is the assumption of the standard k-e model valid: isotropic turbulence? If your flow is swirling/the turbulence is highly anisotropic, you should go for the RNG model.
CFDlearn July 25, 2011 16:01
thank you very much for response
in my problem flow is incompressible
using k-e is valid
it isn't swirling
my question is general ?
Laci July 25, 2011 16:07
using k-e is valid
it isn't swirling
Sorry, but I don't understand you :(:confused:
