Rotor67 planes along blade in streamwise direction |
July 26, 2011, 09:48 |
Preetham
Rep Power: 15 |
Hello Folks,
This is with regard to my project on Rotor67, I needed some surfaces, within the fluid-domain as shown in the attached image. If you could help me with settings within fluent/cfx, to do the same . I need them to periodic like the blade surfaces. The attached image is of NACA rotor. I need similar surfaces on Rotor67. Is it possible to have surfaces through the blade and the endwall recirculation passage as well ? Thank you, Pai |
Calculating lift force of a wind turbine blade problem | LittleBart | CFX | 4 | June 29, 2011 02:33 |
Rotating blade in circular/square vessel (Salome+OpenFoam) | voingiappone | OpenFOAM | 0 | May 19, 2011 11:38 |
Blade tip with tetra/prism method | vinc | ANSYS Meshing & Geometry | 0 | May 17, 2011 15:22 |
stress analysis of a rotating beam(wind blade) | Cheyannne | ANSYS | 0 | October 19, 2009 17:06 |
Meshing a 3D, tapered and twisted blade with Gambit-TGrid | teskio | ANSYS Meshing & Geometry | 0 | July 3, 2009 10:36 |
