Problem with Mixing plane
Old   July 26, 2011, 15:31
Default Problem with Mixing plane
Claudio
Mitpostdoc is on a distinguished road
Hello there,
I am trying desperately to run a simulation of a centrifugal compressor with ideal gas CO2. The machine is running at operating condition (around 80 bar) with ideal gas.
I managed to have a converged solution with density based solver, Implicit formulation and second order upwind schemes for all the fluid properties. However, I am using Axial AREA Averaged mixing plane.
If I try to restart the simulation switching to Mixed-out mixing plane (as recommended by the fluent manual), even with very small CFL and under relaxation parameters, the simulation blows up.
If I look at the results just after applying the mixing-out average mixing plane it seems like a very high pressure is generating around the mixing plane.
Does anyone have any experience using mixed-out mixing plane? I do not see a solution to this problem: The mixed-out mixing plane seems very unstable and as soon as an adverse pressure gradient is built the simulation crashes because of backflow!!! Please, help
Mitpostdoc is offline   Reply With Quote
mixing plane model: too much backflow and does not converge sbhi FLUENT 1 December 4, 2014 01:31
Total mass flow/flux through a plane problem nwalters FLUENT 1 December 18, 2010 13:23
Air & water mixing problem praveenkumar FLUENT 0 April 15, 2010 03:14
Unable to switch from Rotating Reference Frame to Mixing Plane bwg FLUENT 0 July 10, 2009 15:56
Turbine stage mixing plane calculation Knut FLUENT 0 December 4, 2007 13:46
