solid-fluid multiphase,please guide
Old   August 3, 2011, 08:02
Default solid-fluid multiphase,please guide
zino
zino is on a distinguished road
I m trying to model dust and air flow.If I use
1) Eulerian: its taking too much time. how can I reduce time?
2) mixture is producing seperated surfaces. how can I make them granular?
3)VOF through user guide does nt seem appropriate. is it appropriate?
please guide me. need assistance
zino is offline   Reply With Quote
Old   August 4, 2011, 02:55
Default Residuals
Shashank
shashank312 is on a distinguished road
I would suggest that you:
1. Try changing the under-relaxation factors and residual values if you need to decrease the clock time of each time step/iteration.
2. Use a better machine if possible.
Eulerian model is the best for your case.
shashank312 is offline   Reply With Quote
heat transfer between solid and fluid Devy FLUENT 4 June 4, 2010 00:28
conjugateHeatFoam: Should solid and fluid have the same mesh at the coupled boundary? awacs OpenFOAM Running, Solving & CFD 6 September 22, 2009 22:58
coupling solid and fluid cells?? kcg Siemens 4 March 13, 2007 09:39
urgent: heat transfer fluid to solid marco FLUENT 1 October 28, 2005 22:17
