Home > Forums > FLUENT
negative static pressure
Old   August 3, 2011, 08:25
Default negative static pressure
Juan
Tres is on a distinguished road
Hello
I am trying to compute head losses in a pipe 3D. When i have made the simulation I have got good results but i do not understand very well because i have got negative static pressure. Could anybody explain to me the meaning of a negative static pressure?
Tres is offline   Reply With Quote
Old   August 3, 2011, 11:50
Amir's Avatar
Amir
Amir is on a distinguished road
Originally Posted by Tres View Post
Hello
In incomperssible flow solvers, gauge pressure is solved, so negative pressure means that the pressure is lower that your operating pressure.
Amir
Amir is offline   Reply With Quote
Old   August 5, 2011, 07:58
Default static pressure negative
Juan
Thank you Amir
According to your reply I am not sure if i should change my operating pressure because the head losses i have got are very similar to experimental values i have measured. Should I change my operating pressure or maybe it is not important?
I have used velocity inlet and outflow as boundary conditions
Thank you
Old   August 5, 2011, 08:13
Amir's Avatar
Amir
Thank you Amir
Thank you
Dear Juan,
you are talking about head loss which means difference between heads, so if you have set any value for your operating pressure, you'd obtain same result; because:
pressure_head_difference=(p1-p2)/(rho*g)=((p1+C)-(p2+C))/(rho*g)
C=any arbitrary value
this discussion is valid only for incompressible flow.
Amir
Old   August 5, 2011, 08:51
Juan
Thank you
So if I would want to know the real static pressure I should define other boundary conditions such as pressure inlet or outlet because if I introduce velocity inlet and outflow fluent does not compute the real satic pressure. Is it right?. How can I compute the real static pressure in to the pipe?
Thank you again
Old   August 5, 2011, 09:04
Amir's Avatar
Amir
No, it's not right!
Even when you are using pressure conditions, you have to set gauge pressure not absolute one.
In incompressible flow, if you want to find absolute pressure, you would need pressure of one reference point, othrewise, it's not a big problem; after simulation, you can shift your results in order to coincide reference pressure.
Bests,
Amir
Thread Tools
Trackbacks are On
negative static pressure !!!! Barbara FLUENT 14 June 28, 2013 19:04
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Average static pressure BCs and aircore in cyclone KM CFX 2 December 17, 2007 21:50
Pressure averaging at the outlets. KM CFX 2 November 23, 2007 14:50
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
