August 3, 2011, 08:02 |
solid-fluid multiphase,please guide
zino
Rep Power: 16 |
I m trying to model dust and air flow.If I use
1) Eulerian: its taking too much time. how can I reduce time? 2) mixture is producing seperated surfaces. how can I make them granular? 3)VOF through user guide does nt seem appropriate. is it appropriate? please guide me. need assistance |
August 4, 2011, 02:55 |
Residuals
Shashank
Rep Power: 15 |
I would suggest that you:
1. Try changing the under-relaxation factors and residual values if you need to decrease the clock time of each time step/iteration. 2. Use a better machine if possible. Eulerian model is the best for your case. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
heat transfer between solid and fluid | Devy | FLUENT | 4 | June 4, 2010 00:28 |
conjugateHeatFoam: Should solid and fluid have the same mesh at the coupled boundary? | awacs | OpenFOAM Running, Solving & CFD | 6 | September 22, 2009 22:58 |
coupling solid and fluid cells?? | kcg | Siemens | 4 | March 13, 2007 09:39 |
urgent: heat transfer fluid to solid | marco | FLUENT | 1 | October 28, 2005 22:17 |
