November 14, 2018, 10:34 |
Identify residuals
André
Rep Power: 10 |
Hi guys,
does anyone know if any of the newer versions of Fluent allow you to plot / locate residuals like x-momentum or energy, and not just mast balance? It is quite frustrating since that would help pinpoint where issues might be, whether they are related to physics or mesh. Thanks in advance!
Sapere aude! |
November 14, 2018, 10:41 |
Lucky
Rep Power: 65 |
You have to enable an option to save the cell residuals by typing in the following command into the TUI:
solve/set/expert n y n n the y enables the option in "Save cell residual for post-processing?" Then make sure you do some new iterations to generate and create these fields (and possibly save the new cas & dat file if you want to use a post-processor). Then there will be variables under the residuals category that you can visualize within Fluent. They will also now be saved into the .dat file and you can also see them in a post-processor like tecplot or CFD-Post. |
November 14, 2018, 12:00 |
André
Rep Power: 10 |
Thanks a lot!
Sapere aude! |
Why did the residuals increase after flattened out as I continued the iteration? | pchoopanya | ANSYS | 1 | May 20, 2018 03:31 |
plot residuals | pigna | OpenFOAM Running, Solving & CFD | 2 | December 19, 2014 02:32 |
motorBike Residuals for SST k-omega... and mine | JR22 | OpenFOAM Running, Solving & CFD | 6 | August 1, 2013 09:08 |
judging convergence through residuals | MachZero | Main CFD Forum | 7 | December 25, 2012 12:18 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
