Home > Forums > FLUENT
remeshing grid cannt be split
Old   August 6, 2011, 23:13
Default remeshing grid cannt be split
sunrain
sun_rain is on a distinguished road
Hello, I met a question in the remeshing grid. The tri grid can not be split when the length of the grid is out of the maximum length scale, and it is only stretched.
Who has met such question?
Can you give q hand?
The case and UDF profiles as follows.
Thanks.
Last edited by sun_rain; August 6, 2011 at 23:17. Reason: I cant send the case and UDF profiles
sun_rain is offline   Reply With Quote
Old   August 6, 2011, 23:27
sunrain
Thanks.
sorry, I cant send the attachment.
It is a cylinder, the total height is1mm, the radius is 30mm. The top 0.5mm is tri grid while the bottom 0.5mm is quad. A interface connect the two cylinder.
The two interface faces and the bottom face of the cylinder are downstream with the velocity of -0.001 in Z axis.
Old   November 1, 2011, 05:23
stb
snailstb is on a distinguished road
Have you solve this problem? I also meet the same problem. Mesh can not be remeshed, but only strech till negtive volumn exists. Do you have some points for it. Waiting for your help.
snailstb is offline   Reply With Quote
Thread Tools
Trackbacks are On
[ICEM] Split O grid BrolY ANSYS Meshing & Geometry 1 July 2, 2010 09:23
Dynamic Grid Remeshing causing Divergence? Andrew Wick FLUENT 0 January 23, 2006 19:39
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
