November 20, 2023, 15:45 |
3D velocity contour in ANSYS Fluent
Panagiotis Artemiou
Rep Power: 2 |
I want to visualize the flow velocity in a 3D channel, I understand that "contours" in graphics tab can only provide 2D contours as i can only select a surface to plot the contours (a plane or an existent geometry surface for example). But I want to visualize the velocity in 3D. How can I do that? I have tried the "pathlines" option but again only shows the velocity at the surface (the channel walls in my case). Is there a way to do that? Thanks! |
November 20, 2023, 21:15 |
Alexander
Rep Power: 34 |
select interior instead of boundary
best regards ****************************** press LIKE if this message was helpful |
contours |
Can we a create spatial-temporal velocity profile in Ansys Fluent? | DnyanMiri | FLUENT | 1 | February 15, 2022 01:59 |
How to make contour in cross section in helical pipe by using ANSYS FLUENT 17.2? | teguhtf | FLUENT | 0 | November 21, 2018 02:48 |
How to present the value next to the contour lines for ansys fluent? | lem | FLUENT | 0 | September 25, 2016 21:00 |
How to calculate velocity of rising bubble in Ansys fluent using VOF model | BUSHRA KHATOON | Fluent Multiphase | 0 | July 19, 2016 01:18 |
Drawing a velocity profile as inlet boundary condition in Fluent ANSYS ???? | hasanifte | FLUENT | 2 | February 18, 2015 12:44 |
