Recovering Fluent surfaces in ParaView
Like Tree2Likes
  • 2 Post By alemenchaca
Old   August 10, 2011, 12:12
Default Recovering Fluent surfaces in ParaView
Alejandra
alemenchaca is on a distinguished road
Hi!
I'm in the process of divorcing Ensight (crashes wayyy too often), and considering ParaView as my new tool to visualize Fluent simulation results.
Everything is going smoothly, except that I can't figure out how to read/identify the surfaces I had already defined in my Fluent simulation (floors, ceiling, people, etc).
Many old posts recommend using Filters -> Extract Data, but that filter doesn't seem to exist anymore. I've tried all of the "Extract <something>" filters and none seems to do the trick.
I'm reading my data files raw from Fluent (without going through the Ensight format) because all the posts I read regarding exporting data seemed to be very old and from times when ParaView did not offer to option to read .cas/.dat files.
I'd really appreciate some help!
alemenchaca is offline   Reply With Quote
Old   August 11, 2011, 01:26
Raashid Baig
cfd_newbie is on a distinguished road
Originally Posted by alemenchaca View Post
Hi!
I think what you mean is that you have defined some boundary conditions in Fluent which are not appearing in Paraview. I dont think it's possible, until you have define them as separate geometric entity during meshing itself, Paraview will see no difference between them. This is what I think and have experienced, but again I never used the Fluent RAW data and always used the Ensight Binary format in Paraview.
cfd_newbie is offline   Reply With Quote
Old   August 11, 2011, 09:50
Alejandra
Thanks cfd_newbie. You are right, I'm trying to recover my original boundary conditions. I should have specified that those BCs were defined during meshing, and not on Fluent itself, just as you mention I should do.
Also, I tried exporting into Ensight Gold format (the only Ensight format Fluent will let me export in), which gives me an .encas file, but Paraview will only read what it calls Ensight Gold but is an .case file.
Do you knwo if there's any other file format that I could export on so that I can retrieve my original BCs?
Thanks!
Old   August 11, 2011, 09:53
Raashid Baig
Thanks!
Yes Ensight Gold format is the best format for Paraview(!) your *.encas file is correct just rename it to *.case and it should work, (do not change the names of other EnSight files).
Old   August 11, 2011, 09:57
Alejandra
Interesting. I renamed the format and Paraview gave me an error yesterday. I'll try it again then and let you know what happened. So if I import it as .case I should be able to recover my BCs?
Old   August 11, 2011, 15:42
Alejandra
Ok, I was able to read my .case file on Paraview (somehow Paraview doesn't seem to like names with spaces, so that was the error I was getting previously).
So now I can recognize my pre-defined BCs when looking at the case in "Outline" form, but I don't know how to modify them or recover them...
Any clue?
Old   August 11, 2011, 15:52
Alejandra
Found it!!
I just need to run the filter "Extract Block".
All set!!
Anwer and lev like this.
fluent, paraview
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 04:09
Creating a line/edge from the intersection of two surfaces jdwarren FLUENT 0 February 1, 2011 19:11
From FLUENT data to Paraview bart weisser FLUENT 1 July 16, 2010 04:41
Fluent connection with simulink by TCP/IP Tanktruck Fluent UDF and Scheme Programming 1 June 28, 2009 12:56
