divergence detected in two phase flow after thousands of iterations?! |
August 16, 2011, 15:05 |
Emanuel G Marsis
I am simulating a two phase flow in a pump, air and water, and i am using Euler Euler multiphase model... i reduced my under relaxation factors to 0.1 and 0.2 and the model runs fine in the begining... after thousands of iterations it just explodes, and gives the error message " divergence detected" or the temperature or turbulent viscosity exceeded the limits... when i turn off my energy equation and use constant density gas, it does not do that... however i need to use ideal gas with the energy equation... any suggestions?! Thanks.. Last edited by emanuel.marsis; August 17, 2011 at 12:12. Reason: adding tags |
icoLagrangianFoam OF1.6 myNewParticleSolver | heavy_user | OpenFOAM | 23 | June 2, 2020 02:18 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 13:38 |
TurbFoam problemlarge Co number | sunnysun | OpenFOAM Running, Solving & CFD | 6 | March 10, 2009 08:05 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
Negative value of k causing simulation to stop | velan | OpenFOAM Running, Solving & CFD | 1 | October 17, 2008 05:36 |
