Home > Forums > FLUENT
divergence detected in two phase flow after thousands of iterations?!
Old   August 16, 2011, 15:05
Default divergence detected in two phase flow after thousands of iterations?!
Emanuel G Marsis
emanuel.marsis is on a distinguished road
I am simulating a two phase flow in a pump, air and water, and i am using Euler Euler multiphase model...
i reduced my under relaxation factors to 0.1 and 0.2 and the model runs fine in the begining... after thousands of iterations it just explodes, and gives the error message " divergence detected" or the temperature or turbulent viscosity exceeded the limits...
when i turn off my energy equation and use constant density gas, it does not do that... however i need to use ideal gas with the energy equation...
any suggestions?!
Thanks..
emanuel.marsis is offline   Reply With Quote
Thread Tools
Trackbacks are On
icoLagrangianFoam OF1.6 myNewParticleSolver heavy_user OpenFOAM 16 February 11, 2012 06:15
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 14:38
TurbFoam problemlarge Co number sunnysun OpenFOAM Running, Solving & CFD 6 March 10, 2009 09:05
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
Negative value of k causing simulation to stop velan OpenFOAM Running, Solving & CFD 1 October 17, 2008 05:36
