Can not to interpret UDF
Old   June 15, 2009, 06:06
Default Can not to interpret UDF
Alexander Sventitskiy
AlexanderSventitskiy is on a distinguished road
Hallo,
I have a problem with interpreting my UDF. The UDF defunes unsteady boundary conditions and looks as
#include "udf.h"
DEFINE_PROFILE(unsteady_mass_flow, thread, position)
double fact=1.E-06;
double S=1.5E-03;
double t, mass_flow;
face_t f;
t=RP_Get_Real("flow-time");
mass_flow=fact*57.6975*sin(6.2832*t);
begin_f_loop(f, thread)
F_PROFILE(f, thread, position)=mass_flow;
end_f_loop(f, thread)
Fluent reports the following error:
cpp -I"C:\Fluent.Inc\fluent6.3.26/src" -I"C:\Fluent.Inc\fluent6.3.26/cortex/src" -I"C:\Fluent.Inc\fluent6.3.26/client/src" -I"C:\Fluent.Inc\fluent6.3.26/multiport/src" -I. -DUDFCONFIG_H="<udfconfig.h>" "D:\Fluent data\Mask_test\Simulation\mfsin.c"
Error: D:\Fluent data\Mask_test\Simulation\mfsin.c: line 1: parse error.
What can it be??
Thank you.
AlexanderSventitskiy is offline   Reply With Quote
Old   June 15, 2009, 21:52
Eric
duaiduaihu is on a distinguished road
Originally Posted by AlexanderSventitskiy View Post
Hallo,
#include "udf.h"
double fact=1.E-06;
double S=1.5E-03;
face_t f;
What can it be??
Thank you.
i have interpreted it in my computer,no error。。。。。。。。。
duaiduaihu is offline   Reply With Quote
Old   June 16, 2009, 11:13
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
First thing, it is better to compile it.
Second thing, use real in place of float and double.
There is no error with your UDF. Just use compiled one and it will work
vinerm is offline   Reply With Quote
Old   June 17, 2009, 07:07
What is an advantage to use real instead of double?
The problem with the UDF was that FLUENT could not read file from WordPad. After I had used Notepad++ everything was ok.
Thank you for your replies.
Old   August 18, 2011, 08:10
shaoda169 is on a distinguished road
Hallo,
#include "udf.h"
double fact=1.E-06;
double S=1.5E-03;
face_t f;
What can it be??
Thank you.
you should add the udfconfig.h in your working directory. The header file can be downloaded from internet.
Hope this helps you!
shaoda169 is offline   Reply With Quote
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 06:43
interpret or compile an UDF (emergency) Lotfi FLUENT 1 August 26, 2007 12:58
Not able to interpret UDF Prasad FLUENT 1 August 15, 2007 08:44
Interpret three UDF for property Atsu FLUENT 4 April 22, 2006 15:04
UDF Interpret - Syntax Error Leonard FLUENT 1 October 22, 2005 10:06
