Volume Split by face
1 Attachment(s)
I have a volume shown in the attached figure. The face (shown in red) is used to split the cubical volume (shown in pink). But when i try to split volume with the face, Gambit gives the following error:
ACIS error 8062: edge split at one end: may be coincident geometries in input body. How to cope up with this issue? Thanks |
Is your split surface real or virtual? what about your volumes?
Thanks Max
All the volumes and faces are real. |
Then extend wour surface in +y and -y direction (sweep edge)
Also extend your surface in -x for the front edge, and in -z for the rear one. The reason is to be sure that your surface will split all the volume. If it fails, then we will do it in virtual |
Thank you Max
Actually i solved the issue by Stitching the faces first and making a volume and then splitting the volume by volume. However, i also tried what u specified, I extruded surface and edges but it didnt work. Virtual geomtery might work. But the issue is solved. Thanks |
