-   -   Divergence detected in AMG solver: ads-0 (http://www.cfd-online.com/Forums/fluent/91882-divergence-detected-amg-solver-ads-0-a.html)
Patrino August 25, 2011 08:04
hello,
i try to simluate a normal supersonic nozzle. everything worked fine before i wanted to improve my y+ value. therefore i increased the mesh size near the wall. if i run it now with the same values, i always get the error
Divergence detected in AMG solver: ads-1
Error: floating point exception
Error Object: #f
would be glad if anyone could help me
br
stuart23 August 25, 2011 20:48
Hi
Are you using the density based solver? Implicit or Explicit?
What AMG cycles are you running? V, W, F or flexi? Also did you increase the number of levels when you went up a mesh size?
Stu
Patrino August 26, 2011 08:28
I'm using density based solver implicit. Also using standard V cycles and I didn't improve the levels when i increased the mesh size. I only increased the mesh size near the wall so I get a lower y+ value.
shahid nadeem April 9, 2014 10:40
Hello Dear FRiends can you tell me what does level means
jakeme April 18, 2014 01:53
how‘s going that error? hey,brother,i need your help
grv November 25, 2015 10:04
hey, i am facing the same problem. have u got the solution with uniform mesh size. before refining mesh near wall. and one more thing it is a problem with axi-symmetric case only. it work fine for planner case.
