June 6, 2011, 12:51 |
Variable Density Function
Ryan Z. Davis
Rep Power: 16 |
Hi all,
I'm having trouble using the variable density function in FLUENT. I'm doing a simple differentially heated natural convection cavity (2D) and I'm defining density as a function of temperature. When I perform the simulation with air as the working fluid the density does not calculate correctly. During post processing I plot the data for temperature and density and when I perform hand calculations for density (based on the temperature given) I get a different density than what FLUENT calculates. Does FLUENT use any other factors when calculating the density of a fluid? Am I doing something incorrectly? The density function I use is given below. rho = (0.000013491 x (T^2)) - (0.0046555 x T) + 1.12881 Thanks, Ryan |
August 25, 2011, 14:16 |
NormalVector
Rep Power: 15 |
You may have already figured this problem out as it has been a few months since your post but I'll have a go at it:
Make sure that you're entering the polynomial into FLUENT correctly. The boxes are for the coefficients increasing from 0. So, the first box is for the coefficient of T^0, the second for T^1, etc. |
density udf, natural convection |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
Density of liquid Sapphire as function of temp. | J.W.Ryu | FLUENT | 0 | September 8, 2003 02:24 |
