May 16, 2006, 17:29 |
COMSOL or Fluent ?
Hi everyone,
I am new with CFD analysis. I have a few questions about COMSOL and Fluent: 1) What is the difference between COMSOL and Fluent. Do they have the same function? 2) In your opinion, which program will be better for oil and gas industry. ie, i need to deal with sloshing model and flow model. Thanks in advance for your advice. siao fei |
May 17, 2006, 14:55 |
Re: COMSOL or Fluent ?
Forget COMSOL. This is easy to use for small problems (academic, 2D, etc) but not for realistic cases. You should either consider one of the large suppliers like ANSYS-CFX, Fluent, StarCD.......
Astrid |
May 17, 2006, 20:56 |
I agree. If you're more in the 'Open source'[1] or more rigorously 'Free software'[2] spirit, I would highly recommend using OpenFoam[3]. I've been a Fluent user for about 3 years now, and I'm making the transition to OpenFoam simply because it offers me more freedom to tweak every aspect in detail.
[1] http://www.opensource.org/ [2] http://www.gnu.org/philosophy/free-s...r-freedom.html [3] http://www.opencfd.co.uk/openfoam/index.html |
May 18, 2006, 16:55 |
Is openfoam a software to simulate foam and foaming flows?
May 18, 2006, 21:09 |
No. If you read the webpage correctly, you'll see that it is a general purpose CFD code that can even do DNS if you want. It has most capabilities already. Interface tracking VOF, Eulerian bubbly flows, etc. etc.
August 29, 2011, 23:44 |
Reza
Rep Power: 16 |
Hi MAC ,
I dont know any thing about C++ (which openfoam is based ) . I want to use the VOF level set method . Do I need to learn C++ in order to use openfoam ? or is it just as like using commercial codes with no GUI ? Cheers Reza |
August 30, 2011, 06:55 |
Maxime Perelli
Rep Power: 41 |
if you don't want to developp your own solver, you don't need to learn C++.
Just use solvers which are already available.
In memory of my friend Hervé: CFD engineer & freerider |
Display Modes | |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
fluent parallel problem in win7 x64 system | dunga82 | FLUENT | 8 | April 19, 2012 20:23 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 16:41 |
COMSOL or Fluent ? | siao fei | Main CFD Forum | 0 | May 16, 2006 15:07 |
