two zones two mesh
4 Attachment(s)
I need to have a model with "layering'' scheme of dynamic mesh. Hence I split my model into two zones with different types of mesh (hex/wedge above and tet/hyb bottom) as attachment. These zones actually might consider as one zone with two types of mesh. My problem is what boundary condition should I set for the face connecting these zone? Is it interior? My results seem like different from only one zone with (tet/hyb for whole volume with one zone. Correction pls. It is urgent.
You have to set both surface boundary conditions as interfaces.
Then create an interface, name it whatever, and select the inner set of faces for one of the surfaces, and the outer set of faces as the other surface. Fluent will interpolate between the two surfaces even if the mesh is non conformal. Stu |
