Home > Forums > FLUENT
ERROR vof model !!!
Like Tree2Likes
  • 1 Post By tobino
  • 1 Post By sail
Old   September 1, 2011, 08:04
Default ERROR vof model !!!
Tobino
tobino is on a distinguished road
Hi, has anybody meet the same this error.
yousefi95 likes this.
tobino is offline   Reply With Quote
Old   September 1, 2011, 11:28
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
which one are you referring to? there are more than one.
turbulence viscosity ratio limited to... refers to turbulent quantities. possibly your initial condition are quite far from the solution so a limiting is in place to prevent the simulation to diverge.
the backflow means that the fluid is coming into the domain from the outlet, instead of going out. I'd say pressure-related or mesh problems
it is hard to be more specific without knowing the problem and how the simulation has been set up.
sail is offline   Reply With Quote
Old   September 1, 2011, 12:57
Harpreet
Harpreet is on a distinguished road
i am also facing similar conditions, but the flow profile is coming almost ok, with some overshooting in the velocity.
does it also means some problem in B.C.'s or mesh
Harpreet is offline   Reply With Quote
Old   September 1, 2011, 19:34
Tobino
Thanking for rely,
My model is a hull with vof model, 2 phase air and water. I set BC following:
1. Define model: 3D, steady, vof, k-epsillon standard wall funtion
2. Phase: primary phase - air , secondary-phase water
3.Operating condition: operating pressure 101325, gravity z = -9.81
4. Boundary condition: air-inlet with velocity inlet, water-inlet with velocity inlet.
air-outlet with pressure outlet gauge pressure 0. water outlet with pressure outlet gauge pressure 0.
5.Solution control: PISO, Body force weighted.
6. Solution initialization: compute from all-zones, reference frame absolute. init.
7. Solve initialize, patch: phase water, value 1, zones to patch fluid, registers to patch hexahedron-r0, patch.
Old   September 2, 2011, 11:02
sail's Avatar
Vieri Abolaffio
Thanking for rely,
try to initialize from the inlet
Thread Tools
Trackbacks are On
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 04:41
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
