How can I use NITA in VOF and UDS (separately)? |
April 9, 2012, 19:20 |
Igor
Rep Power: 14 |
Hi!
My task contains two part. 1. I solve UDS. 2. Then I use obtained data as source term and try to solve task with VOF and NITA. (and I want to repeat it some times) But... If I have UDS - of course turned off in EQUATIONS - I got message: "noniterative solver is not available with UDS." What can I do to fix it? Of cource I can remove UDS -but then I lose the data. Best regards... |
April 19, 2012, 09:44 |
According to the tasks you need to accomplish you may consider the use of user defined memories instead. Usually the biggest difficulty is in the computation of gradients which require some additional coding (a Green-Gauss cell based algorithm can be easy to be done). Sometimes (but probably not now), the temperature equation can be used conveniently
April 19, 2012, 13:11 |
Igor
Rep Power: 14 |
Yes. Now I use UDM and copy data from UDS to UDM, then remove UDS, then solve VOF, then create UDS... And I should do it ten times.
I do not understand the creators of Fluent in this case... but - it is the method to stimulate study of Scheme-programming. |
nita, uds, vof |
melting + vof modeeling for PCM in air | taw | FLUENT | 2 | August 24, 2018 00:21 |
need help about UDS & VOF | mengyue1 | FLUENT | 7 | February 7, 2014 17:40 |
How can i set different diffusivities for UDS using VOF? | DaddySpeleo | FLUENT | 1 | March 28, 2012 18:57 |
Doubts UDS Flux, UDS Unsteady for VOF model | kel85uk | FLUENT | 0 | March 17, 2010 08:53 |
Urgent! Access violation of UDF using VOF | Rucy | FLUENT | 0 | January 9, 2006 04:01 |
